Processors
13560 Discussions
intel e97379-003
RIMINI
Ciao a tutti
ho questo tipo di ventola
ma si sono rotti i piedini
e non appoggia perfettamente
nei suoi buchi
mi chiedevo se esiste una ventola  più potente
che si adatta ai buchi esistenti
grazie
VarshaS_Intel
We only provide support in English. I have translated your question. Please find the below question:
intel e97379-003
Hello everyone
I have this type of fan but they broke their feet and does not rest perfectly
in its holes. I was wondering if there is a more powerful fanthat fits into existing holes
Thank you
Does this reflect your question correctly? Let us know so that we could redirect this issue to the right forum for better assistance.
Thanks & Regards,
Varsha
RIMINI
perfect
thank you
Jean_Intel
Hello RIMINI,
Regarding your question, multiple fans in the market may replace the one you are using. However, to know if the fan will help your system, you should identify which is the socket of your motherboard and check with the Fan manufacturer if they have a device that supports your motherboard socket; usually, fans support multiple sockets.
Jean O.
n_scott_pearson
Super User Retired Employee
The hole placement for the 'feet' of the heatsink-fan unit are standardized and there are plenty of replacements from Intel and from third parties. Sites like Amazon and eBay list literally hundreds of alternatives and replacements. There are alternatives that you can purchase that will increase the heat dissipation capability and support upgrade processors.
On Amazon, you can find a replacement E97379-003 heatsink-fan unit here: https://www.amazon.com/Intel-E97379-003-Connector-Aluminum-Heatsink/dp/B01LWMGRX6 (this is an example, there are other sources available through Amazon as well). If you want to upgrade, you could look at a basic heatpipe design such as this: https://www.amazon.com/Vetroo-Cooler-Processor-Universal-Addressable/dp/B08F21X2VP or a premium design such as this: https://www.amazon.com/Noctua-NH-D9L-Premium-Cooler-NF-A9/dp/B00QCEWTAW.
Hope this helps,
RIMINI
thanks for your patience
you have been very helpful
thank you
Jean_Intel
Hello RIMINI,
I appreciate your response.
We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
