Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
intel pentium dual core t2330 1.6 GHz - Up-grade-able??
I am new to this forum so im not sure if im posting in the rite place.....but here is my issue... im using a hp compaq C751nr laptop and this is the stock processor....it is really simply horrible....i is only good for basic aplications....ive upgraded my ram up to 2 gigs....but i cant even play the most bottom line games with issues with lag....therefore i want to upgrade....im not sure if i can and i would love some surgestions to wat i should upgrade to...please help me out any inof will help... thankyou
John_S_Intel
Any discussion of upgrading your processor should probably start with the manufacturer (or OEM) of your system (HP/Compaq?). See what they recommend (if anything). Your options will depend upon which chipset (CPU socket) you have as well as what processors the system BIOS will support. You can check the processors that are comparable to your processor on ark.intel.com, but if the BIOS currently only supports the T2330, then you'll have to get an updated BIOS from the OEM for a new processor to work. In addition, any assistance you require in the actual process of swapping out the CPU and thermal interface material would have to come from the OEM (system manufacturer).
John S.
Intel Customer Support
*Other names and brands may be claimed as the property of others.
Community Manager
Try using readyboost off most flash drives, it will help your games run somewhat smoother.
RGiff
Honored Contributor I
Go to the HP Parts surfer and look up all the parts for your modle and that list will tell you what the up-grade options are , I have a DV-9023 , it came with a t-5200 1.6 core 2 duo. Looked it up and found I could use a T-7200. with changing anything but the CPU.
