I've tried reinstalling the tool and restarting, still the same results. My computer seemed to be running extremely slow so I tried this tool and got a failure halfway through.
Here is the log:
--- Genuine Intel Test ---
Version 1.0.16.32b.W
Expected -- GenuineIntel
Detected -- GenuineIntel
Genuine Intel CPU Module Success
--- Brand String Test ---
Version 1.0.20.64b.W
IntelR CoreTM i7-7700HQ CPU 2.80GHz
Brand String Module Success....
--- Cache Test ---
Version 1.0.16.64b.W
--- Reading Cache Size ---
- Detected L1 Data Cache Size -- 32
- Detected L1 Inst Cache Size -- 32
- Detected L2 Cache Size -- 256
- Detected L3 Cache Size -- 6144
Cache Module Success
--- MMXSSE Test ---
Version 1.0.21.64b.W
..DetectUtils64 DLL Version - 1.1.2
--- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
Testing MMX
Dot Product computed using C code 506
Dot Product computed using MMX intrinsics 506
MMX Dot Product Computation Test Passed
Passed MMX Test
Testing SSE
Dot Product computed using SSE intrinsics 506
SSE Dot Product Computation Test Passed
Passed SSE Test
Testing SSE2
Complex Product computed using C code 23.00 -2.00i
Complex Product computed using SSE2 code 23.00 -2.00i
SSE2 Complex Product Computation Test Passed
Passed SSE2 Test
Testing SSE3
Complex Product using C code 23.00 -2.00i
Complex Product using SSE3 code 23.00 -2.00i
SSE3 Complex Product Computation Test Passed
Passed SSE3 Test
Testing SSSE3
SSSE3 Absolute Value Tests Passed
SSSE3 Arithmetic Tests Passed
SSSE3 Dot Product Test Passed
Passed SSSE3 Test
Testing SSE4.1
SSE4.1 Blend Tests Passed
SSE4.1 Min Max Tests Passed
SSE4.1 Insert Bit Tests Passed
SSE4.1 Extract Bit Tests Passed
SSE4.1 Bitwise Comparison Tests Passed
SSE4.1 Dot Product Test Passed
SSE4.1 Arithmetic Tests Passed
SSE4.1 Bit Conversion Tests Passed
SSE4.1 Bit Compare Test Passed
Passed SSE4.1 Test
Testing SSE4.2
SSE4.2 Bit Compare Test Passed
SSE4.2 Calculate Bit Set to 1 Test Passed
SSE4.2 CRC Test Passed
Passed SSE4.2 Test
MMXSSE Module Success
--- Integrated Memory Controller Test ---
Version 1.0.12.64b.W
StatusFMmatched 0
--- Reading Memory Size ---
Detected Memory Size is -- 16.00GB
--- Subtest - Memory Size Test Passed ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed ---
--- Integrated Memory Controller Stress Test Passed ---
Parallel_PrimeNum_i7-7
Version - 1.0.0.9
Parsing Parallel_PrimeNum_i7-7.xml
Running Module Math_PrimeNum.exe -s 20 -resultName Math_PrimeNum_Parallel_PrimeNum_i7-7_1_Results.txt
Running Module VisCollisions.exe -step 10 -ws 550 -s 20 -resultName VisCollisions_Parallel_PrimeNum_i7-7_1_Results.txt
Running Module VisParticle.exe -ps 1.9 -ws 700 -s 20 -resultName VisParticle_Parallel_PrimeNum_i7-7_1_Results.txt
Module VisParticle.exe Completed - Fail
No valid errorcode returned
Error Code -1073740771
--- Prime Number Generation Test ---
Version 1.0.19.64b.W
AVX is supported in your OS
Max AVX supported AVX2
Ops Per Sec CycleRun Error Timesec
19910 1 0 1
9700.5 2 0 3
20158 3 0 4
20103 4 0 5
Module Math_PrimeNum.exe Completed - Fail
Error Code -1
Module VisCollisions.exe Completed - Fail
Error Code -1
Result - Fail
Any help would be appreciated.
Hello EthanK ,
Thank you for posting.
In this case, our recommendation is to contact your computer manufacturer for more assistance regarding your question. From my end, we cannot confirm the compatibility for video adapters. We also recommend checking with their support for the supported resolutions for each port included in your hardware.
https://www.samsung.com/support/ https://www.samsung.com/support/
For more information visit: https://ark.intel.com/products/122589/Intel-Core-i7-8550U-Processor-8M-Cache-up-to-4-00-GHz- Intel® Core™ i7-8550U Processor (8M Cache, up to 4.00 GHz) Product Specifications
Amy C
Under Contract to Intel Corporation
