Processors
14526 Discussions
intel ptt problem
guru1
eventhough i enabled intel ptt in the bios it is not showing up in tpm.msc
i don't know why
AlHill
This is not a processor issue.  It is a bios issue, presumably for your NUC, for which you did not state the model number.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
