I installed the most recent version of intel XTU 6.4.1.23. I am running windows 10 1709. When i try to run the stress test for graphics it says it needs to install .net 3.5. I allow it to install. After install I reboot and run XTU. When I choose graphics stress test it fails. graphicsstresstest.exe fails. Any ideas? Another post mentions needing directx? Directx is already installed.
- Tags:
- Intel® Graphics
I have upgraded to Windows 10 1803 and i still have the same problem.
Hello green5178
Thank you for joining the community.
I see that you are having problems to complete the graphics stress test on your unit, allow me to help you with the inquiries.
In order to help you better, I would like to gather more information about the configuration you have on the computer. Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Steps to save the report:
- Run the utility.
- Click on "Scan" to get the scanned system.
- Once the scan is complete click on "next".
- Use the "save" option, save the report to your desktop.
- To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Could you also run the Intel® Processor Diagnostic Tool? Please provide me with the .txt file report.
Download link: https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Hope this help.
Leonardo C.
Thanks for your help. I have attached both results.
Hello green5178
Thank you for your response.
Looking into the Intel® processor diagnostic tool I noticed that the processor is not reporting any failure, let me investigate further the behavior that the Intel® XTU is having while running the stress test, I will be posting back when news becomes available.
Leonardo C.
I didnt think there was a failure on the chip since this happened on 3 different laptops. Also I can undervolt up to -.110 and still be stable. BUT if I undervolt even .05 it will not survive a modern standby. As soon as it sleeps the systems crashes. I did not see a BSOD but event viewer will show unexpected shutdown detected. On reboot intel xtu will automatically restart and say something about error. Other people have mentioned the same problem on reddit.
Hello green5178
Allow me to share with you that in Intel® XTU has been mainly designed for the unlocked processor ( K and Extreme processors), also bear in mind that overclocking/underclocking may cause unexpected behavior to the unit.
Reference link for Intel processor numbers for K (unlooked processor):
https://www.intel.com/content/www/us/en/processors/processor-numbers.html https://www.intel.com/content/www/us/en/processors/processor-numbers.html
Let me share with you the following link information about overclocking:
https://www.intel.com/content/www/us/en/gaming/overclocking-intel-processors.html https://www.intel.com/content/www/us/en/gaming/overclocking-intel-processors.html
Could you provide me with the model of laptops that you have used and the processor model?
Leonardo C.
I have tried it on Thinkpad X1 Yoga 3rd generation and Thinkpad X1 Carbon 6th generation. All have I7-8650U
Hello green5178
Thank you for your response and for the information provided, I will be investigating this behavior allow me some time to do so, I will be posting back when news becomes available.
Leonardo C.
I am having the same problem with my X1 Carbon 6th Gen with i5-8350U. System will reboot whenever it goes to sleep regardless of how little offset I apply.
Llamallama,,
Does yours fail the graphics stress test too? I posted problem here but i have seen it posted on reddit and other forums people having same problem.
green5178, it passes the stress test. But it doesn't survive entering sleep mode. Yes, I've seen other posts as well, but the solution seem to be switch to Throttlestop... I'm not aware of any solution /w XTU.
llamallama,
Yours passes the GRAPHICS stress test? Mine passes the CPU and memory stress test. It fails on the GRAPHICS stress test.
Leonardo,
Any updates? Its been almost 3 weeks since the initial post.
Hey there
Apologies for the late response. As far as I know mine 'still' probably fails the stress test on the GPU. However what I can deduce is it is caused through essentially having 2 GPU's - and it is neither of them 'failing' but the software used..
I did a test online and my machine scored high in every single field, but the GPU. Upon investigation, the site measured Intel's dGPU and not the more powerful nvidia graphics card... Yet on Cinebench, the machines GPU scored highly because their software measured the Nvidia graphics card instead..
So, from what I could tell, its usually all software dependent and the reason why our machines failed their stress test using Intels programme is due to their programme getting confused (or that's what I have put it down too haha)
Sorry if everything I have said is incorrect, its all just my assumption from the tests I done
All the best
Gabriel
Ggarcia I agree its a software problem. X1 yoga and X1 carbon only have integrated graphics yet it still fails.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
