Processors
16105 Discussions
intel xtu signature validation failed i9 10900k
guiduz
I can't get this utility to work.
It always starts with this error.
I'm running the latest bios software.
Please advise.
DeividA_Intel
Hello guiduz,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Core™ i9-10900K Processor.
1. Did the tool used to work?
2. Do you have any other overclocking tool/Performance Tuning Application installed?
3. Do you have the antivirus enabled?
4. Did the tool come preinstalled on the computer?
Deivid A.
guiduz
Hey Deivid
Thanks for your reply.
I have never used the tool before and I don’t remember if it was pre installed.
I have MSI afterburner installed for the gpu.
I don’t use any antivirus.
DeividA_Intel
Hello guiduz,
Thanks for the confirmation. Based on your issue, please try the following:
1. Reboot your system and rerun the Intel® XTU installer.
2. Uninstall Intel® XTU by following the "How to Uninstall the Intel® Extreme Tuning Utility (Intel® XTU)" article. Then, proceed to reinstall it.
3. Make sure you have the latest BIOS version installed. You may want to contact the board manufacturer to ensure this.
4. Try a fresh Windows installation.
Deivid A.
guiduz
I followed all the steps but I'm still getting the same "XTU signature validation error".
G
DeividA_Intel
Hello guiduz,
Thanks for your response. I am sorry to know that the issue persists, in order to investigate this behavior, please provide the following:
Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
Deivid A.
guiduz
Attached the required log file.
G
DeividA_Intel
Hello guiduz,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello guiduz,
Thanks for your patience. I would like to let you know that to maximize the overclocking experience and utilize the full functionality of XTU. For an i9-10900K Intel recommends using a compatible Overclocking (OC) Chipset (Z) like the Z490 or Z590. All other chipsets do not support overclocking.
Also, make sure that you are using the latest Intel Extreme Tuning Utility (XTU) version 7.11.1.5. Let me know if you are using this version.
For signature validation errors in general, you may try to uninstall Intel® Extreme Tuning Utility (Intel® XTU) and then manually delete the c:\program files\Intel(R) Extreme Tuning Utility\ directory. However, that would require you to be an admin and to be very careful not to delete any other program folders by default.
Deivid A.
DeividA_Intel
Hello guiduz,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
guiduz
Hey Deivid
I have replaced the motherboard with a new Z590 chipset and will let you know.
Gee
DeividA_Intel
Hello guiduz,
Thanks for the information. I understand that will need some time to test the Intel Extreme Tuning Utility (XTU) with the new motherboard.
I will be waiting for your response.
Deivid A.
DeividA_Intel
Hello guiduz,
I reviewed your post, please let me know if the issue was resolved, if not, do not hesitate, just reply back.
Deivid A.
guiduz
I still get the same error.
DeividA_Intel
Hello guiduz,
Thanks for the confirmation. Before we continue, I would like to confirm if you tried the previous recommendations with this new board.
"For signature validation errors in general, you may try to uninstall Intel® Extreme Tuning Utility (Intel® XTU) and then manually delete the c:\program files\Intel(R) Extreme Tuning Utility\ directory. However, that would require you to be an admin and to be very careful not to delete any other program folders by default."
If the issue persists, please run the Intel® System Support Utility (Intel® SSU) and share the report:
Deivid A.
guiduz
Attached the required system scan.
DeividA_Intel
Hello guiduz,
Thanks for your response. I will continue with the investigation and as soon as I have any information I will get back to you.
Thanks for your time and comprehension.
Deivid A.
DeividA_Intel
Hello guiduz,
Before I continue with the investigation I would like to confirm the following:
1. Did you manually delete the directory from c:\program files\Intel(R) Extreme Tuning Utility\ ?
2. Did you try a clean reinstallation of the operating system?
Deivid A.
guiduz
Of course I deleted the folder (which is deleted automatically).
I won’t do a clean installation of the OS just because your software doesn’t work.
Please provide a solution.
DeividA_Intel
Hello guiduz,
Thanks for the confirmation. I will check for any additional steps to troubleshoot this issue, I will get back to you as soon as possible.
Deivid A.
DeividA_Intel
Hello guiduz,
Thanks for your time. Based on the steps performed so far, I recommend you try the following:
2. Uninstall Intel® XTU by following the How to Uninstall the Intel® Extreme Tuning Utility (Intel® XTU) article.
3. Download and install the latest version of Intel® XTU.
4. Make sure you have the latest BIOS version installed. You may want to contact the board manufacturer to ensure this.
Admin permission is required for this step: manually delete the c:\program files\Intel\Intel(R) Extreme Tuning Utility directory. Be very careful not to delete any other program folders by default.
5. If the issue persists, update Windows or try a fresh Windows installation.
If the steps don't fix the error message, then unfortunately, this error could be an indication of a Dynamic Link Library (DLL) file mismatch. These files are an essential component of Windows and many programs and applications on a computer.
DLL files exist in different versions and don't contain any instructions, they can be difficult to find or can be corrupted. Sometimes, a simple reboot will fix the problem. Other times, it may take an OS update or fresh install. Since you changed the system components, it is likely the case.
Deivid A.
