Processors
16455 Discussions
is the cpu temp accurate in microcode 0x104 for z790
beeee
hi,
i have seeing lots of cpu tuning guides about reducing the voltage and temperatures of cpu. most of them suggest to use microcode 104 which shows a significant reduction in cpu temperature compared to other microcode versions at the same level of cpu voltage.
however some said the cpu temps reported in 0x104 are wrong / underreported.
can you clarify the accuracy of the temp sensors in microcode 0x104?? because these guides are still suggesting 0x104 over 0x12b for max temp reduction.
thanks,
bee
ArchieD_Intel
Hi beeee,
I would like to confirm that when it comes to temperature, the quality of the motherboard and CPU thermal components, as well as the accuracy of measurement points, play a significant role. Unlike voltage measurements, which can fluctuate, temperature readings are more consistent and reliable.
Regarding the 0x104 BIOS, it was originally designed for overclocking without limitations on PL1, PL2, and ICCmax, and without the mitigations we have developed. Using this BIOS version may have led to CPU degradation and instability issues. We strongly recommend updating to the latest BIOS version to ensure a more stable system.
For specific temperature details related to the 0x104 BIOS, we advise contacting your motherboard vendor, as the sensors are integrated within the BIOS/motherboard. They will be able to provide more detailed information.
If you have any questions or need further assistance, please feel free to reach out.
Archie D.
ArchieD_Intel
Hi beeee,
Thank you for contacting the Intel Community Forum. To help us investigate the issue, please provide the following information:
  • What is the specific model of the motherboard you are referring to?
  • What cooling solution or fan are you using?
  • How are you monitoring your system's temperature? Are you using third-party applications or Intel XTU?
If you have any questions, feel free to reach out to us. Thank you!
Archie D.
beeee
asus z790 apex encore
13900k
360mm aio
both intel xtu and hwinfo
ArchieD_Intel
Hi beeee,
Thank you for your update!
I'll begin looking into this with the details you've provided, however, to give you a more accurate information, the exact make and model of the motherboard you're referring can greatly help us. I'll keep you informed here as soon as there are any developments. Your patience while I work on this is greatly appreciated.
Archie D.
ArchieD_Intel
Hi beeee,
I would like to inform you that the precision of temperature sensors in microcode versions, including 0x104, can be affected by various elements such as the CPU model, motherboard, and system setup. While microcode updates are designed to enhance CPU performance and stability, they might also alter the reporting of certain metrics like temperature.
For the most accurate details, I recommend reviewing the official documentation provided by the motherboard manufacturer. They can provide valuable information on how different microcode versions may impact temperature reporting and overall CPU performance.
In addition, could you please provide any reference or link related to microcode version 0x104 so we can verify it as well?
Archie D.
NormanS_Intel
Hello beeee,
Thank you for providing the source of the information. We will review this inquiry and update you in this thread once more information is available.
Norman S.
ArchieD_Intel
Hi beeee,
Archie D.
