Processors
15436 Discussions
laptop processor upgrade
erdalduran10
Asus s550cm dizüstü bilgisayarım
intel i7-3537u 2.0 ghz proseccor
paket 1023 fcbga 22nm intel hm76 sarmaşık köprüsü 09
En yüksek özellikli işlemciyi dizüstü bilgisayarıma sorunsuz bir şekilde kurmak istiyorum.
hangi intel işlemcileri satın almalıyım?
erdalduran10
I want to install the highest specification processor on my laptop without any problems.
which intel processors should i buy?
AlHill
You have to ask ASUS what processors are supported by THEIR BIOS.  Then, you can select from those.   However, your processor is soldered to the motherboard (or on a daughter card).   If on the motherboard, you have no chance of upgrading (unless you replace the entire motherboard).  I doubt the processor is on a daughter card.
Whatever the case, you likely have no upgrade path.   Far a laptop this old, it is time for you to consider a laptop replacement.
erdalduran10
Thanks but ı will not buy a new computer.
