Processors
13836 Discussions
less processor performance Intel Core i5-7200U - Intel HD 620 less performance 2D graphics
Serhio
Hi
I have a laptop E5-575G-53V2
https://www.acer.com/ac/ru/RU/content/support-product/6737?b=1
Processor
Intel Core i5-7200U @ 2.50GHz
Intel HD 620
GTX 950M
There are two moments that cannot be eliminated.
After reinstalling, the OS has a question mark device - PCI memory controller.
ID
PCI\VEN_8086&DEV_9D20&SUBSYS_00000000&REV_21
(has not an exclamation point, but a question mark)
The description says:
"This device is not currently connected to your computer. (Code 45)
To resolve this issue, connect your device to your computer. "
If I delete a device, it appears with an exclamation point.
Installed all the drivers of the manufacturer and also DCH driver through Intel Support Assistant.
Also, after reinstall OS, passmark test readings fell
15% less processor performance.
50 percent less performance 2D graphics.
Something works wrong. But it's not clear what. He turned to TS Acer, but they said that all the drivers were laid out and there were no problems on their part.
Can someone help and clarify the situation?
JosueO_Intel
Hello Serhio,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Was it working fine before the reinstallation of the OS?
  2. Have you checked the issue with Microsoft?
  3. Did you use a fresh copy of Windows to perform the reinstallation?
  4. Screenshots of the issues.
Also, please download and install the Intel System Support Utility (Intel SSU):
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".
Click on "Next", save the report and attach it to your response.
Josue O.
Serhio
- Was it working fine before the reinstallation of the OS?
There were errors in the OS logs. Sometimes there were crashes in the games, a blue screen. Now I have increased the RAM to 16 GB and so far there have been no sorties.
- Have you checked the issue with Microsoft?
No. Microsoft does not provide technical advice. advise only on product activation and updates. So the TP specialist told me.
- Did you use a fresh copy of Windows to perform the reinstallation?
I used a fresh copy of Windows to reinstall.
Iak tried to clone OS on another disk and reset by resetting to its original state. The result is the same performance also dropped after the reset.
- Screenshots of the issues.
JosueO_Intel
Hello Serhio,
Josue O.
Serhio
Sorry for the delay. Attached the data above in the topic.
Serhio
The report is taken from the OS which shows the maximum performance. In order for you to have data. I am now using the installation that came with the laptop as it is the most productive in the tests.
JosueO_Intel
Hello Serhio,
Thank you for the information provided, in this case, please download and run our Intel® Processor Diagnostic Tool, this will run a series of tests to check the functionality of the processor and check if everything is working as expected. Run the test and share a screenshot of the results.
https://www.intel.com/content/www/us/en/download/15951/intel-processor-diagnostic-tool.html
Josue O.
Serhio
Here is the report
JosueO_Intel
Hello Serhio,
Josue O.
JosueO_Intel
Hello Serhio,
In this case, our recommendation is to check with the system manufacturer for warranty options for your system.
Hope this information is useful, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Josue O.
Serhio
This is useless information. Acer didn't help me. They said that all the drivers are posted on the site. And the fact that they are old does not bother them.
I was hoping for your help.
