Processors
16299 Discussions
mise en route de mon pc
thierry78
bonjour a tous
je viens de finir de monter mon nouveau pc :
gigabyte b760 ds3 h ddr4 lga 1700 atx
après avoir mon ma CM mon  CPU  I5 12400 et mon ventilateur, le pc ne s allume pas??
pouvez vous m aider.
cordialement
Senkuchan
Valued Contributor II
refer to these links for the troubleshooting steps:
https://www.intel.com/content/www/us/en/support/articles/000021605/processors.html
https://www.gigabyte.com/FileUpload/Global/WebPage/351/images/troubleshooting.pdf
To identify the root cause of the issue, you need to consider many factors that may affect the no power on issue. Also, you need to verify that everything is compatible and connected correctly.
You can also check the motherboard manual for guidance on how to set up the system properly: https://www.gigabyte.com/Motherboard/B760-DS3H-DDR4-rev-10/support#support-dl
