hello
does anyone know a compatible Intel motherboard which will run on Pentium 4 3.0GHz 1MB 800MHz FSB 478-pin (SL7E4 ), board must support maimum of 4gb ram with 4 Dimm slots
pls advise
- Tags:
- CPU
Check these boards:
Intel® Desktop Boardhttp://www.intel.com/support/motherboards/desktop/DQ965CO/ DQ965COhttp://www.intel.com/support/motherboards/desktop/dq965co/sb/CS-022977.htm Manual, http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2373 BIOS & drivershttp://www.intel.com/support/motherboards/desktop/DQ965GF/ DQ965GFhttp://www.intel.com/support/motherboards/desktop/dq965gf/sb/CS-022976.htm Manual, http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2372 BIOS & drivershttp://www.intel.com/support/motherboards/desktop/DP965LT/ DP965LThttp://www.intel.com/support/motherboards/desktop/dp965lt/sb/CS-022910.htm Manual, http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2374 BIOS & driversIntel® Desktop Boardhttp://www.intel.com/support/motherboards/desktop/D975XBX2/ D975XBX2http://www.intel.com/support/motherboards/desktop/d975xbx2/sb/CS-023492.htm Manual, http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2578 BIOS & driversAll the best,
Aryan.
