Configuration of my laptop:
Windows 10 64-bit
Intel Pentium processor N4200
Nvidea 920mx
4 GB RAM
Epic Games Launcher installed but not run (the process is reset in Task Manager Windows). Without him can not install the Fortnite.
When contacting Epic Games Support him technician write me minimum system requirements.
Here are the Minimum System Requirements:
* Windows 7 64-bit or Mac OS X 10.9.2 or later running the latest version of Metal
* Dual-core Intel or AMD processor, 2.5 GHz or faster
* Direct X 11 compatible GPU
* 4 GB RAM
Epic Games Launcher installed, updated but not run (the process is reset in Task Manager Windows).
Here's my system information file.
I think that the whole problem is that Epic Games Launcher reads my configuration system with a base frequency 1.1 GHz but not with a maximum 2.5 GHz and he resets because of the frequency is less than acceptable.
I already wrote Epic Games. They are already solving this problem. They've been working on it for over a year. It is difficult for them to write exceptions in Epic Games Launcher for Intel CPU with core name Apollo Lake.
As I wrote Epic Games Launcher reads information from the configuration of the system (like most games) which contains only the base frequency of 1.1 GHz. Launcher is reset because the frequency is less than the minimum to run. Help with this problem. Try to make changes to the system configuration.
For example, NBA 2K19 I have on high graphics settings with a great framerate. Although the game is more demanding.
Thank you in advance.
I have already written Epic Games and Unreal Engine about the problem. This compatibility problem has been solved for about 2 years. And it takes minutes to solve it. A normal user was able to run a clone of UE4. If the user managed to start UE4 on these processors means the solution is. https://forums.unrealengine.com/unreal-engine/feedback-for-epic/1503637-openssl-error-when-starting-...
That's why I'm asking the company to see if you can influence them. All users of CPU core name which Apollo Lake still can not use Unreal Engine 4 and all applications and games on this engine.
Did you try disabling speedstep? This way your cpu would be detected at its maximum rather than minimum or idle state.
