Community
cancel
Showing results for
Search instead for
Did you mean:
jsoll2
opencl runtime not executing clEventCallback
Hello everyone,
I am developing a program using openCL 1.2 on linux on a i5-7600 on linux-4.14
The program is built using event-based programming:
this part executes it callback:
err = clEnqueueNDRangeKernel(in_devs[i].command_queue, in_devs[i].kernels[in_devs[i].hosting_iterator->current_char % 4], 3, NULL, globalworkids, localworkids, 0, NULL, in_devs[i].event);
if(err != CL_SUCCESS) {
printf("clEnqueueNDRangeKernel for device %d failed. skipping item %d \r\n", i, err);
pass->mapping[i] = -1;
err = clSetEventCallback(*(in_devs[i].event), CL_COMPLETE, nextevent, pass);
printf("clSetEventCallback for device %d failed. skipping item %d \r\n", i, err);
continue;
clFlush(in_devs[i].command_queue);
This part does not:
void CL_CALLBACK nextevent(cl_event event, cl_int event_command_exec_status, void* user_data) {
jp_event_passthrough* process = (jp_event_passthrough*) user_data;
cl_uint err;
printf("launching next event on %d \r\n", process->deviceid);
err = clEnqueueReadBuffer(process->devlist[process->deviceid].command_queue, process->devlist[process->deviceid].args[3], CL_FALSE, 0, process->devlist[process->deviceid].hosting_iterator->current_char + 4, process->resp, 1, process->devlist[process->deviceid].event, &(process->multiple_use));
err |= clSetEventCallback(process->multiple_use, CL_COMPLETE, nextReadevent, process);
printf("Problem while read result from device %d %d \r\n", process->deviceid, err);
process->mapping[process->deviceid] = -1;
return;
clFlush(process->devlist[process->deviceid].command_queue);
// clReleaseEvent(event);
the problem does not occur on the nvidia opencl runtime (installed on the same pc), and does not occur on windows on a Xeon E5-2643 cpu.
What am I doing wrong?
any suggestions are welcome
Community Manager
Hello jpsollie
Thank you for joining the community.
I see that you are looking for information/assistance on app development, to better assist on your inquiry please refer to our Intel® Developer Zone, please refer to the following link:
https://software.intel.com/registration/ https://software.intel.com/registration/
Leonardo C.
