Processors
15870 Discussions
please help, 13900kf pcore 0 issues
phil29
Hey, i recently built this pc with the following specs:
MB: Gigabyte z790 aorus elite ax ddr5
CPU: intel 13900kf
RAM: 32 gb Corsair vengeance rgb 7200 cl34
GPU: rtx 4080 gaming oc
Power: Be Quiet Straight Power 12 platin 1000w
windows 10 pro
 the cpu seems to work fine besides one thing, pcore 0 is always dropping to its minimum specification if i look at hwinfo64, on intel xtu the core frequency also seems to be dropping to a weird 0 ghz, i wonder what is going on here, please help im slowly losing my mind with this,  i didnt heavily overclock the cpu or anything, the temps are always fine, i tried to set the vcore to fixed with about 1.4v and that was it in terms of voltage changing, highest llc tested was medium, all cores seems to work fine except pcore 0 which is doing this weird stuff
i start wondering if my cpu is maybe damaged or something because this doesnt seems normal
DeividA_Intel
Hello phil29,
Thank you for posting on the Intel® communities. I understand that you are having an issue with the P-Cores. To help you on this matter, please provide the following:
1. From the picture, I see the P-cores at 5.50GHz and the E-cores at 4.30GHz. Can you take a shot video and pictures from the Intel® Extreme Tuning Utility (Intel® XTU) where I can see the issue you described?
2. What is the Windows 10 version and build?
3. What is the BIOS version installed?
4. Do you have any overclocking settings enabled in the BIOS?
5. Run the Intel® Processor Diagnostic Tool and share the report:
Deivid A.
DeividA_Intel
Hello phil29,
This follow-up is to confirm if the issue related to P-cores is still present and if you need further support.
Deivid A.
DeividA_Intel
Hello phil29,
I was checking your thread and noticed that we have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
