Processors
13891 Discussions
problema con xmp
takemura72
buongiorno
ho un i512600k su scheda madre z690 ddr5
con 2 banchi ram kingston fury beast 5600mhz
se le ram vanno a 4800 mhz tutto funziona
ma se abilito profilo xmp da 5600 mhz nel bios il pc non parte
help
n_scott_pearson
Super User Retired Employee
Consult the motherboard online documentation for information regarding the memory speeds supported.
takemura72
gia fatto
la mobo gigabyte z690 gaming x ddr5 supporta fino a 5600 mhz oc
quindi non capisco
n_scott_pearson
You'll need to consult with Gigabyte regarding compatibility; they own the motherboard implementation (including the BIOS memory initialization firmware).
megan3000
Valued Contributor I
I would add that you are also exposing the CPU to damage... despite the motherboard can support 5600MT/s with OC, this 12th Gen CPU supports up to 4800 MT/s for DDR5... so you are trying to go 800MT/s beyond the CPUs specs... IMO, that seems to be the most probable reason why it won't boot
https://ark.intel.com/content/www/us/en/ark/products/134589/intel-core-i512600k-processor-20m-cache-up-to-4-90-ghz.html
