Processors
14500 Discussions
¿puede in procesador intel core i5 funcionar con memorias ram ddr4 a 2400mhz?
LGóme
hola, estoy por comprarme in procesador intel core i5 5600 y tengo la duda si funcionara con memorias ram ddr4 a 2400mhz o bajara su frecuencia?
n_scott_pearson
While many of the 6th generation Core i5 processors list 1866/2133 as their maximum, most should have no issues running at 2400. Those that do not can operate these same DIMMs at 2133.
n_scott_pearson
The 5th generation Core i5 processors do not support DDR4 memory. They only support DDR3 memory.
LGóme
Me equivoqué en el modelo del procesador, quería saber si el Intel core i5 6500 soporta memorias ram ddr4 a 2400mhz.​
n_scott_pearson
Leonardo_C_Intel
Hello LGóme Scott is correct above, however, we recommend checking with the motherboard manufacturer since they will validate the compatibility and support for the processor, BIOS and memory with their board. Here is the specification sitefor the Intel® processor: https://ark.intel.com/products/88184/Intel-Core-i5-6500-Processor-6M-Cache-up-to-3-60-GHz- Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
