Processors
14538 Discussions
q8400 massive overheating
Hi i recently bought a quadcore q8400 processor and installed it in my pc,
since i have done so the pc fails to load windows or go past the post screen and when i looked into why i found the cpu was on about 92 degrees celcius... i have had a core 2 before and replaced the heatsink that came with the cpu for a much more powerful zalman on.
(see http://www.zalman.co.kr/Eng/product/Product_Read.asp?Idx=378 for the specific zalman product and details)
There is a correct ammount of thermal paste spread evenly between the processor and the heatsink. so my question is my processor broken? should i send it back and ask for a replacement? or is there any way of trying to remedy the issue?
thanks
aguy1
also i've replaced the heatsink with the stock one and it wont even boot.. it just makes the motherboard come out with a processor heatsink missing error....
hope this helps
aguy1
Please check that your processor is in the list of compatible processor for your motherboard.
http://www.abit.com.tw/page/uk/motherboard/motherboard_detail.php?pMODEL_NAME=Fatal1ty+FP-IN9+SLI&fMTYPE=LGA775
as you can see from this link it supports quad core processors and i upgraded the bios to the latest version before attempting to install the processor...
thanks
aguy1
Sorry, I'm not familiar with your board. Perhaps you can find the answer to your problem in the the board manufacturer's website.
hey i am also getting same problem with same processor
one of my friend told me use heat solution for decrease heat
i am going to try this
RGiff
Honored Contributor I
If you have room in your case , Look at the Coursair H-50 or hte H-70 Cooling solutions.
Thank you very much
thanks for all the replies i found the problem was in the bios in the end and i fixed it by loading an experimental bios on and fiddling with the vtt until i achieved stability.
The bios can be found here incase anyone else requires it.
http://www.theraptorpit.com/forum/index.php?showtopic=2629 http://www.theraptorpit.com/forum/index.php?showtopic=2629
