estou em um projeto de power bi para fazer insign para meu site ___ e meu canal do youtube (channel) objetivo criar relatorios integrado mais meu proccessador nao sei se vai aguentar poderia me indicar um processador da intel bom porq sao os melhores obrigado
Moderator's note: removed hotlinks
Hello gaspar
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool.
We understand you would like a recommendation for an Intel® Processor in order to use it with Power BI. We are not sure if you refer to Power BI Desktop, Power BI Report Server, or any other variant.
However, it is worth mentioning that this recommendation should come directly from the software developer. Because Intel provides a wide arrange of products for different needs, we recommend comparing Intel® Processors using the Product Specifications Page (ARK) to choose the processor that better suit for you. To do this, please follow the instructions in this link:
How to Compare Intel® Processors Using Product Specifications Page (ARK)
https://www.intel.com/content/www/us/en/support/articles/000027710/processors.html
In addition, you may check the following links* about Minimum Requirements for Power BI; however, we highly recommend checking this with Microsoft Support since they are the ones that handle all the technical details about this software. In this scenario, the software vendor is the best channel of support.
- https://docs.microsoft.com/en-us/power-bi/fundamentals/desktop-get-the-desktop#:~:text=Minimum%20requirements,-The%20following%20list&text=Power%20BI%20Desktop%20will%20no,of%20Power%20BI%20Desktop%20only.&text=Memory%20(RAM)%3A%20At%20least,1.5%20GB%20or%20more%20recommended.
- https://docs.microsoft.com/en-us/power-bi/report-server/system-requirements
Andrew G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel® or any of its products is implied.
Hello gaspar
We would like to know if you were able to review our previous post. If you need further assistance regarding the proper hardware (including processor) for this software our recommendation is to check this further with the software vendor (Microsoft*) for proper recommendations. Here is the Microsoft Support* link:https://support.microsoft.com/
Andrew G.
Hello gaspar
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer being monitored.
Andrew G.
