Processors
16309 Discussions
showing wrong results
pelo1
I have a EVGA RTX 3060 oc Gaming GPU with 12 GB of RAM and XTU is showing only 4 GB.
pelo1
Hi Steven,
I do appreciate your humour. You must have ancestors from England. «...all the other information SHOULD BE correct.», it just make it more obscure.
Denis Péloquin
Steven_Intel
Hello pelo1,
In order to better assist you, please provide the following information:
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
pelo1
Here is the sreen shot as asked. Have a good day.
Pelo1
Steven_Intel
Hello pelo1,
Thank you for your response.
While I received the SSU report, it seems the screenshot of XTU showing the 4 GB of RAM instead of 12 GB was not attached.
Please provide the screenshot in order to continue researching this issue.
Steven G.
pelo1
Hi Steven,
Here is the screen shot
Steven_Intel
We are going to work on this case and as soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Hello pelo1,
Intel XTU is not designed to report/monitor third party hardware, i.e. information provided by the tool on Nvidia Graphics card may not be accurate.
We recommend you to use tools from Nvidia or EVGA to confirm proper graphics functionality.
As for Intel Integrated graphics (6th gen and newer), the VRAM will always be capped at 50% of total RAM capacity (e.g. if the system has 8GB of RAM, then the max VRAM for Intel Integrated graphics is going to be 4GB)
Please let me know if you have any concerns.
Steven G.
pelo1
Good thinking. If you know that data is not accurate why showing it? It put a doubt about the rest of the data.
Have a good day.
Denis Péloquin
Steven_Intel
We appreciate the feedback since that help us improve our tools in the future. I do want to clarify that all the other information should be correct.
I recommend you to keep checking the VRAM information from tools created by the graphics card manufacturer.
If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
pelo1
Hi Steven,
Denis Péloquin
