Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
switching hyperthreading on & off from the OS (not from the bios!)
Hi
is it possible to switch HT off and on again from Windows operating systems?
My processor supports HT, and i can disable and enable HT from the BIOS. I know.
The question stems from the need to optimize certain and different CPU-intensive programs at certain times, without restarting the computer.
I know that this is possible from linux. but i didn't find a way to do it from windows XP/7.
alternatively, is there a way to temporarily disable and then enable single processorts? (again, from Windows, without going thru the bios)
thank you
Highlighted
Community Manager
1 View
Have you checked this link?
http://www.intel.com/support/processors/sb/CS-028855.htm http://www.intel.com/support/processors/sb/CS-028855.htm
Let me know after you have read it, till i try to see if there is any other things that i can refer to you.
All the best,
Kind Regards,
Aryan
