Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12589 Discussions
temperature difference between two i9's
DM7
I have two identical PCs each with i9-7920X CPU and TUF X299 MARK 2 motherboard. Although BIOS settings are default CPU cores on the second PC show a bit higher temperature than on the first PC. The difference around 5 degree C. The output of i7z utility is below.
First PC:
Cpu speed from cpuinfo 3024.00Mhz
cpuinfo might be wrong if cpufreq is enabled. To guess correctly try estimating via tsc
Linux's inbuilt cpu_khz code emulated now
True Frequency (without accounting Turbo) 3025 MHz
CPU Multiplier 29x || Bus clock frequency (BCLK) 104.31 MHz
Socket [0] - [physical cores=12, logical cores=12, max online cores ever=12]
TURBO ENABLED on 12 Cores, Hyper Threading OFF
Max Frequency without considering Turbo 3129.31 MHz (104.31 x [30])
Max TURBO Multiplier (if Enabled) with 1/2/3/4/5/6 Cores is 44x/44x/44x/44x/44x/44x
Real Current Frequency 4581.92 MHz [104.31 x 43.93] (Max of below)
Core [core-id] :Actual Freq (Mult.) C0% Halt(C1)% C3 % C6 % Temp VCore
Core 1 [0]: 4477.79 (42.93x) 100 0 0 0 52 1.2317
Core 2 [1]: 4477.79 (42.93x) 100 0 0 0 52 1.2188
Core 3 [2]: 4477.79 (42.93x) 100 0 0 0 54 1.2617
Core 4 [3]: 4373.65 (41.93x) 100 0 0 0 54 1.1666
Core 5 [4]: 4465.49 (42.81x) 99.8 0 0 0 58 1.2408
Core 6 [5]: 4376.97 (41.96x) 99.8 0 0 0 55 1.1875
Core 7 [6]: 4477.79 (42.93x) 100 0 0 0 54 1.2539
Core 8 [7]: 4477.66 (42.93x) 100 0 0 0 58 1.2330
Core 9 [8]: 4477.79 (42.93x) 100 0 0 0 61 1.2617
Core 10 [9]: 4477.79 (42.93x) 100 0 0 0 55 1.2122
Core 11 [10]: 4477.79 (42.93x) 100 0 0 0 52 1.2043
Core 12 [11]: 4581.92 (43.93x) 100 0 0 0 55 1.2188
On second PC:
Real Current Frequency 4583.35 MHz [104.31 x 43.94] (Max of below)
Core 1 [0]: 4583.35 (43.94x) 100 0 0 0 59 1.2422
Core 2 [1]: 4479.19 (42.94x) 100 0 0 0 61 1.2551
Core 3 [2]: 4479.19 (42.94x) 100 0 0 0 61 1.2551
Core 4 [3]: 4479.18 (42.94x) 100 0 0 0 57 1.2317
Core 5 [4]: 4479.19 (42.94x) 100 0 0 0 61 1.2629
Core 6 [5]: 4583.35 (43.94x) 100 0 0 0 61 1.2578
Core 7 [6]: 4479.19 (42.94x) 100 0 0 0 60 1.2473
Core 8 [7]: 4479.19 (42.94x) 100 0 0 0 58 1.2617
Core 9 [8]: 4479.19 (42.94x) 100 0 0 0 63 1.2617
Core 10 [9]: 4479.19 (42.94x) 100 0 0 0 61 1.2408
Core 11 [10]: 4479.19 (42.94x) 100 0 0 0 63 1.2617
Core 12 [11]: 4479.19 (42.94x) 100 0 0 0 61 1.2551
In the first case average temperature is 55C and 60.5C for the second. What could cause the difference? Is it BIOS/motherboard issue or that temperature variation is normal?
thanks,
Dmitry
n_scott_pearson
Super User Retired Employee
There are all sorts of things that can have an affect on this variation: differences in TIM applied, differences in fan speed control programming for processor, differences in response of processor cooling fan/blower/pump, differences in internal and external ambient temperature, differences in fan speed control programming for chassis, differences in response of chassis fans, differences in effectiveness of processor cooling solution. I could go on, but I think you get the message...
DM7
Understood. I have impression than VCore is bit higher for second cpu. Can temperature mode affect VCore?
thanks,
Dmitry
n_scott_pearson
VCore can affect temperature, but temperature mode cannot affect VCore.
