Processors
14536 Discussions
upgrade Core 2 Quad Q9000
ARodr32
Buenas queria hacer una consulta, tengo una laptop DELL Studio 1555, Core 2 Duo, con 6GbRAm DDR2 800, TC. retroiluminado, con Windows 7 64bits, y le puse un Core 2Quad Q9000, es fabuloso... pero cuando voy a Intel Driver Upgrade Utility 2.8.1 me dice que tengo para una actualización de BIOS A13, lo descarga pero a la hora de correrlo me sale DELL COMPUTER FLASH UPGRADE BIOS DEJO DE FUNCIONAR.. QUE PUEDO HACER... DE ANTEMANO LE AGRADEZCO POR LA RESPUESTA..
Hello 950284138,
Thank you for joining the Intel® Community.
Just for you to know this utility is intended to be used on Intel® motherboards and kits, it can be used on third-party motherboards but is likely to encounter inconveniences like the one you are reporting. In your case Dell should be able to provide a tool for this purpose, and in case is not available you can always try to install the drivers manually from their site.
Amy C.
ARodr32
Gracias amigo...
/thread/116185 950284138, you're welcome.
Amy C.
