Processors
14536 Discussions
virtualization
luffy11
intel® çekirdek™ i5-3210m laptopumda vt x açamak için Yardıma ihtiyacım var
n_scott_pearson
Your processor certainly has support for VT-x, but this doesn't necessarily mean that your laptop has support. The feature is enabled by the laptop's BIOS. If the BIOS it does not enable support, it isn't going to work. Can you verify that the feature is enabled once you are in your O/S?
luffy11
bios does not appear on the menu so how do I use android on my laptop ?_
n_scott_pearson
You have to look in BIOS Setup for the enabling parameter. If you cannot find one, there is still the possibility that the laptop enables it regardless. Either way, run a tool that checks and displays whether or not the virtualization capability has been enabled in the O/S. If not, you will have to contact your laptop manufacturer to find out if an updated BIOS is available that allows for this capability (presuming they will even talk to you about a laptop this old).
