Processors
14523 Discussions
whether the DIMM be retrained every time when I do CPU_reboot
JerryYang
Background: The Skylake platform has two cpus and eight DIMMs. After the mass production devices have been running for a long time, the CPU system may fail to work due to the reboot or power-on and power-off of the entire device. The port80 message is 0x26 or 0x30.
Two points of doubt:1.DIMM parameter Settings are critical. If you restart the device, you need to train the DIMM again,but in sometime re-process, the training is not suitable and the system hangs 2.During the running of the device, the BIOS records the abnormal status. As a result, the device cannot get up during restart
My question: 1. whether the DIMM be retrained every time when I do CPU_reboot or power on and off the whole machine? 2. Is there any factor that causes the BIOS to be modified during device operation?
Victor_G_Intel
Hello JerryYang,
To continue with your request can you please provide the following information:
  1. Please provide the exact model of the CPUs and DIMMs been used.
  2. When you say retrain/train the DIMM do you mean that you have to re-seat a DIMM or some of the DIMMs so the system can come back up?
  3. Is this server system an Intel® Data Center Block?
  4. Before the issue started did any changes related to hardware or software happened on the system?
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello JerryYang,
Please let me know if you need further assistance.
Victor G.
Victor_G_Intel
Hello JerryYang,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer be monitored
Victor G.
