Processors
16438 Discussions
xtu not opening
MertoKnight1
intel xtreme tuning utility doesnt open. Firstly i tried downloading the latest version 10.0.1.31. but it said i was on an unsupported platform. My OS is windows 11 23h2. Secondly i tried downloading the older version 7.14.2.14. But it also didnt work. There was an error message and i took i screenshot of it
RandyT_Intel
Hi @MertoKnight1,
Please try uninstalling XTU by following our guide on How to Uninstall the Intel® Extreme Tuning Utility (Intel® XTU) and manually install Intel® XTU version 7.14.2.14, as this version supports unlocked Intel® Core™ processors (14th gen) and older.
If the issue persists, please provide the verbose logs so we can check this internally.
  1. Open Registry Editor
  2. Find HKEY_USERS\.DEFAULT\Software
  3. Create a new Key named “Intel” under that node (if it doesn’t already exist)
  4. Create a new Key named “XTU” under the “Intel” node (if it doesn’t already exist)
  5. Create a new DWORD value under the “XTU” node called “LoggingLevel” with value 4
  6. Restart the XTU Service, or restart the computer.
  7. Start XTU and reproduce issue
  8. Share new XtuCore logs available in C:\ProgramDate\Intel\Intel Extreme Tuning Utility\Logs. Specifically the XtuCore file after the issue was reproduced, which will now include additional information details [ INFO ].
Randy T.
MertoKnight1
i did what you wanted still same error i cant open xtu it says drivers arent present
RandyT_Intel
Hi @MertoKnight1,
Please follow the steps on how to provide the verbose logs so we can check this internally. I posted the instruction above. Once I have this information, we can start from there.
Randy T.
RandyT_Intel
Hi @MertoKnight1,
Randy T.
RandyT_Intel
Hi @MertoKnight1,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Randy T.
