Programmable Devices
20693 Discussions
配置芯片替换问题
SYou1
由于EPCS配置芯片停产,所以更换了EPCQA, 如果仍使用Quartus老版本(17之后才支持EPCQA),在不更新下载文件的情况下,是否能加载EPCQA?
YuanLi_S_Intel
Hi Silu,
Apologize that i cannot be. You will need to use new Quartus (v17 and above), change the IP to EPCQA if you are using any configuration IP and regenerate the bitstream for EPCQA.
Thank You
