21611 Discussions
10663 parameter or port?
hsong22
Vicky1
here, you have used the 'DIVPA' parameter for instantiation of module 'clkdiv' & it might not be legal.
please refer the 'Verilog LRM' for '3.4 Parameters ', here it is mentioned that It is not legal to use hierarchical name referencing (from within the analog block) to access external analog variables or parameters.
https://www.accellera.org/images/downloads/standards/v-ams/VAMS-LRM-2-4.pdf
Vicky
Vicky1
May I know any update or Should I consider that case to be closed?
Vicky
hsong22
Oh!sory!yeah, I have found the problem that in some other part the parameter k is defined by wrong spell word, I spell input as inout..you can close it now, thank you! 发送自 Windows 10 版邮件<https://go.microsoft.com/fwlink/?LinkId=550986>应用
