Programmable Devices
20704 Discussions
10AS066H2F34I1HG FIT and MTBF value
Dear sir,
Can I know the FIT(failure in time)and MTBF value of following:
1)10AS066H2F34I1HG
2)EPCQL256F24IN
Can you suggest me External Temperature Sensing Diode that can be used with 10AS066H2F34I1HG?
You can use PN:MAX1619.
Refer the arria10 development kit schematic for interfacing details and handbook page no:310 & 311 for connection guideline.
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/arria-10/a10_handbook.pdf
https://www.altera.com/content/dam/altera-www/global/en_us/support/boards-kits/arria10/soc/production_files/a10_soc_devkit_03_31_2016.pdf
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
What is the difference between 10AS066H2F34I1hG and 10AS048H3F34I2sG? what does h and s indicates?how does it differ from each other?
Refer
https://www.altera.com/en_us/pdfs/literature/sg/product-catalog.pdf
https://www.altera.com/documentation/sam1403480274650.html#sam1403480019500
Anand Raj Shankar
Hi sir,
Thanks for sharing, I am aware of those documents you have shared. It consists of the following power option.
S : Standard
L : Low
M : VCC PowerManager
But customer has provided us with the part number 10AS066H2F34I1HG. Can i know what does that H refer to?
H refers to High performance power.
For more details on this you can check the links in pervious post.
https://www.alteraforum.com/forum/attachment.php?attachmentid=14710
Anand Raj Shankar
We are using 10AS066H2F34I1HG. What is the allowed (minimum and maximum) ppm tolerance for input clock for FPGA DDR4 Clock and HPS DDR4 clock?
Bhavishya AJ
There is no ppm spec for DDR4 refclk. Both FPGA and HPS DDR4 refclk will be connected to IOPLL input clock pin.
For IOPLL input clock spec, we only have jitter spec as shown in attached A10 datasheet.
Anand Raj Shankar
Thanks for your reply.
Where can I get the following documents
1)IBIS model and associated documents
2)insertion and jitter loss documents for 10AS066H2F34I1HG?
Bhavishya AJ
--- Quote Start ---
You can find information in below link.
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/rr/rr.pdf
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd06132000_3184.html
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd12222008_705.html
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd04072012_59.html
Anand Raj Shankar
--- Quote End ---
Hi Sir
can i knw the fit rate at 25degrees for the same?
Bhavishya AJ
