21602 Discussions
10CL010Y BSDL File
MartinSmith
Hello, where can I find the BSDL file for the 256 pin version of the 10CL010Y? I can find the one for 10CL010 but this is incorrect for the silicon I am using and tries to test some GND pins.
AqidAyman_Intel
May I know what is the full device part number?
MartinSmith
FvM
There's only one 10CL010 device in 256-pin package, the BSDL file is here Intel Cyclone 10 LP Boundary Scan Description Language BSDL Files |...
MartinSmith
yes, but this appears to be incorrect for the 10CL010YU256I7G
FvM
Which BSDL pins do you see in conflict with actual pin mapping?
MartinSmith
There are multiple ones, for instance J11 in the BSDL file is entered as...
--BSC group 87 for I/O pin J11
"261 (BC_1, IOJ11, input, X)," &
"262 (BC_1, *, control, 1)," &
"263 (BC_1, IOJ11, output3, X, 262, 1, Z)," &
But on the Intel ref design schematic (doc 150-0321321-A1) it's shown as being GND
I know this is for the 10CL025Y version but they are meant to be pin compatible?
FvM
The 256 pin devices are migration-compatible, not pin-identical. Comparing 10CL010 and 10CL025 pinout would have clarified.
J11 is one of the pins that has to be connected to ground in migration compatible design although it's IO in 10CL010.
AqidAyman_Intel
Hi Martin,
Do you have any more concern on this? Please let us know if there is any.
Aqid
AqidAyman_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
