21273 Discussions
10M16SCU169I7G FPGA open drain ouput pin configuration electrical characteristics
NBK
where can i find electrical characteristics of open drain ouput pin configuration for FPGA 10M16SCU169I7G? I need to know maximum pull-up voltage that we can apply externally to the configured open drain output pin and its VOLmax specifications.
Thanking you in advance.
lixy
Generally the external pull-up Voltage connected to Open Drain I/O should not be higher than I/O bank's I/O standard voltage.
Thanks & Regards,
Xiaoyan
lixy
I wonder if you have any further questions. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
Xiaoyan
