21594 Discussions
16-bit CRC Vs 32-bit CRC
Does anyone know the advantage of using a 16-bit CRC circuitry vs a 32-bit CRC circuitry?
Additional question:
Where can we find this information; how long will the CRCERROR pin stays high after detecting an error?
A 16bit CRC is able to detect a single bit error within 2^16 bit (8kBytes), while a 32bit CRC can detect a singlebit error within 2^32bits (500MBytes)
Rene
Does it mean that the 16-bit CRC is actually faster as the coverage area is smaller?
That may well be. The CRC is basically a self feeded shift register of the named length. So yes, a CRC16 reaches a higher frequency than a 32bit shift register. On the other hand there are faster implementations than the shift register approach. This operates with tables. I've worked with a CRC16 that was using a 256byte table and operated on a word (16bit) at once. It was run on a PC as well as on a controller, years before FPGAs came out. So if speed is an issue, have a look at the table based CRC implementation. It is available for the CRC16 as well as for the CRC32.
Rene
If you don't have to protect more bits that a CRC16 can cover, you better stay with the CRC16 and add a few bits for a better protection. There are codes that can uncover multiple errors as well as forward error correction.
Rene
Guys it seams that you forgot one thing.
The quality of the CRC depends on the size of th input.
You can produce a CRC16 for a 32 bits word, 64 bits word and so on....
So it means that in some case the value of the CRC will be the same for 2 differents input values.... In this case, some errors might not be detected.
I hope this help
A CRC is calculated over all bytes of a block, it is a polynominal over all bits actually.
And that's why I underline that the quality depends on the size of your bloc also and not only of the CRC result size
