Programmable Devices
20644 Discussions
5AGXFB3H4F35I5N/G
John16
5AGXFB3H4F35I5N specified as ROHS5 on the datasheet
5AGXFB3H4F35I5G specified as ROHS6 on the datasheet
Normally ROHS5 is ROHS compliant except for Lead content in the connections (in this case the solder balls)
On the website both are specified as having lead-free solder balls.
Can someone please clarify the difference between N & G packages.
Will N package need to be re-balled to run through a lead-free solder process?
AminT_Intel
Hello John,
I am not clear with your request. Are you asking if the N package can run in a leaded soldering process?
AminT_Intel
Is there any update on your end? I will close this case in 3 days if there is no update from you.
Thank you
John16
What are the solder balls on N package?
PB-Sn or PB-free?
AminT_Intel
The N package is the leadfree solder ball and rightly will run in a leadfree soldering process.
AminT_Intel
 We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
