21611 Discussions
A question about FPGA configuration
ZC0001
Hi,all
I now using MX25L12833FMI-10G/MX25L12835FMI-10G to replace EPCQ128 to configurate CYCLONE V FPGA. The quartus II 18.1  show the successful configuration result. But when I power up the board again, the configuration chip can't configurate FPGA sucessfully. I am confused of this question.
Looking forward your help.
BestRegard.
ZCS
NurAiman_M_Intel
Thank you for contacting Intel community.
May I know what type of configuration scheme that you used?
Aiman
ZC0001
Hi, Aiman
Thanks for your reply.
The configuration mode i used is AS. I have tried ASx1 and ASx4 modes but all failed to configurate FPGA after power up,while download the program to MX25L12833FMI-10G/MX25L12835FMI-10G is successful.
BestRegards.
ZCS
NurAiman_M_Intel
Hi ZCS,
Due to a problem in Quartus 18.1, the AS configuration fails in Cyclone V. Please try the workaround fix in below link:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2018/why-the-active-serial--as--configuration-fails-in-stratix-v--arr.html
Aiman
ZC0001
Hi,Aiman.
I installed the patch for quartus, but it doesn't resolve this problem.
Can you give me some other advice. Thanks.
Best Regards
ZCS
