A10 FPGA 10AX022 VCC的对地阻抗是多少,如果用万用表测量的话,我们发现测量的结果是对地很小的阻值,不到一欧姆,正常吗
Hi BQi,
I couldn't understand your question because of language translation, which resistance are you measuring?
Have you referred the Arria 10 Datasheet?
Try measuring with different boards using the Multimeter or I would suggest you to use oscilloscope to obtain more accurate value.
