Greetings,
I'm designing a Agilex 7 AGIB041R31B2I2V and need the CTM for the PTC tool as well as the STP model for thermal analysis in Solidworks. It looks like my registration needs to be approved before I can access the models?
AN944 notes, "If your company does not use any of the above CFD tools, Intel can provide a step file of the CTM by request.... Step models do not have built in thermal material properties; that data is provided separately, and you must add it to the models." Where do I make this request?
Hi RM16,
The Compact Thermal Model file requires customer to have Non-Disclosure Agreement with Intel/Altera.
I have send you private message to check with you about the NDA.
Thanks!
Xiaoyan
May I know if you still have further requests? Thanks!
Xiaoyan
