Hello.
I'm planning a new hobbyist project (gotta start somewhere) and I'm thinking about using the MAX 10 and I know it will be available until 2035. But I recently discovered that there will be a new low cost AGILEX 3 coming and I was wondering if that will be supported on the Quartus Prime Lite?
Can anyone share some info about the AGILEX 3? Is it non-volatile? How many PLL's? Blocks? Memory?
I'm curious.
Robin Kleven
The features are not finalized yet, but below are the list of features will be available:
- PCIe Gen 3.0 x4
- 10G Ethernet HIP
- Hyperflex fabric ~380MHz
- Transceiver Tx/Rx 12.5 Gbps
- LVDS 1.25Gbps
- MIPI D-PHY 2.5Gbps
- HSIO
- HVIO
- Dual Cortex A55 @800Mhz
- LPDDR4
- SHA-384, ECDSA 256/384, AES-256, side channel attack resistance, cryptographic services, physical anti-tamper support
- and many more.
Performance comparison - 1.8x better than Cyclone V FPGAs
Power comparison - 50% lower than Cyclone V FPGAs
regards,
Farabi
- PCIe Gen 3.0 x4
- 10G Ethernet HIP
- LVDS 1.25Gbps
- HSIO
- HVIO
- LPDDR4
- and many more.
regards,
Farabi
Hi Farabi,
Can you comment if there will be an Agilex 3 serie with non volatile configuration memory, to replace the MAX 10 family?
Agilex3 is not meant to replace MAX10, Cyclone V and Cyclone 10. These device will continue to be available until 2040. Agilex3 will not have non-volatile memory like MAX10. Instead it will have ARM-A55 core.
regards,
Farabi
I have provided the answer, I will return this case to community back. If you have new question, please raise new ticket, we will be happy to help.
regards,
Farabi
It would be nice to have a new device with on-chip flash again, like MAX 10, but I doubt that's going to happen anytime soon, especially with the lifetime extension for those older devices.
