- Email to a Friend
I am migrating from Quartus 13.1 on a 32 bit Windows 7 to 17.1 on 64 bit Windows 10.
My 1000 lines of AHDL code involving LVDS at 960MHz with a Nios II processor and tons of altera megafunctions have done well and I should thank Intel for the continued support for AHDL. I am continuing to use AHDL in my new design with Cyclone 10. Well all work fine except ALTACCUMULATE. This is a pretty simple block. INCLUDE "Altaccumulate"; acc : ALTACCUMULATE WITH (WIDTH_IN = 16, WIDTH_OUT = 18, LPM_REPRESENTATION = "UNSIGNED"); The outputs are always stuck to Gnd. Any help making this megafunction continue to work is future editions is appreciated. RaviLink Copied
- Email to a Friend
ALTACCUMULATE is working fine. Actually it was some timing issue writing to a TRI_STATE_BUS which feeds internal logic. Strangely this behavior occurs for loop lengths of greater than 10.
When I added the nop below everything became alright! psrc = (PUSHORT)(DPR_BASE); pdest = (PUSHORT)(AHDL_IFACE_BASE); for (i=0; i<15; i++) { *pdest++ = *psrc++; asm("nop"); } These pointers are always more elegant than the macros: IOWR_16DIRECT(DPR_BASE, offset, val) IORD_16DIRECT(DPR_BASE, offset) Regards, Ravi
Topic Options
