18457 Discussions
ALTPLL for multiple input frequencies
Honored Contributor I
Hi All,
I have an input clock to MAX-10, which could be 2.5MHz, 25MHz, and 250MHz.
I need to put a PLL on this input clock (for shifting the input clock by 90 degrees).
I don't have any indication what clock (frequency) is currently connected to the pin.
So, how should I configure the ALTPLL? What frequency should I define? What Mode (normal, clock synchronous, etc).
Thank you!
Altera PLLs have a maximum lock range of about 1:2. Also constraints for PFD frequency range.
Changing input frequency over a wider range would require PLL reconfiguration or multiple PLLs. Also input frequency of 2.5 MHz is below specified MAX10 range.
If you can design some logic for determining which of the three frequencies is present, you can dynamically reconfigure the PLL to work with that frequency.
Hi, gj_leeson!
I have the same problem: on one pin may be clock 25MHz or 125MHz and I have a pin, which indicates this - 0 for 25 and 1 for 125.
I read altera manuals about altpll_reconfig with several mif-files. I create the same scheme with two ROMs, MUX, pll_reconfig and pll. I create two mif-files from pll wizard for two input clocks.
And my question: how should I configure the pll? The default PLL settings are for 125MHz, because this situation is more difficult for scheme and TimeQuest timing analyzer. Am I right or not?
What would you advise in this case?
Thanks!
125Mhz default sounds correct.
