I am having troubles interpreting the status register 7 of the altremote_update core in a Cyclone IV device. My application: * FPGA_BOOT -> offset 0x0 * FPGA_APP -> offset 0x20000 Typical flow is: power on -> FPGA_BOOT -> FPGA_APP When starting FPGA_BOOT application, the status register 7 is checked. If this application was loaded because of ...- error condition when booting from FPGA_APP => stop reconfiguration, error message
- user triggered reconfiguration (FPGA_APP triggers boot from FPGA_BOOT) => perform tasks
- power on (first time, no errors, no user triggered reconfiguration) => boot from 2nd image
short int write_fpga_reconfig_param(int param_number, int param_value){
IOWR_32DIRECT(PARAM_BASE, 0, param_number); // param address
IOWR_32DIRECT(DATA_IN_BASE, 0, param_value); // param value (disable watchdog)
IOWR_32DIRECT(WRITE_PARAM_BASE, 0, 0x1); // set write
IOWR_32DIRECT(WRITE_PARAM_BASE, 0, 0x0); // clear write flag
while(IORD_32DIRECT(BUSY_BASE, 0)); // wait for rising edge of busy
return 1; // all writes are succesful...
int read_fpga_reconfig_param(int param_number){
IOWR_32DIRECT(READ_SOURCE_BASE, 0, 0x0); // source 0x2 (previous state reg 2 contents)
IOWR_32DIRECT(READ_PARAM_BASE, 0, 0x1); // set read
IOWR_32DIRECT(READ_PARAM_BASE, 0, 0x0); // clear read flag
return IORD_32DIRECT(DATA_OUT_BASE, 0/*
* direct PIO control -> activate reconfiguration
void trigger_fpga_reconfig(){
usleep(100000);
IOWR_32DIRECT(FPGA_RECONFIG_BASE, 0, 0x1); // trigger reconfig
If I remember correctly, read source for status register must be 01 for previous configuration.
Then you must set IOWR_32DIRECT(READ_SOURCE_BASE, 0, 0x1);- Mark as New
Hi Chris, thanks for the tip, now I am able to read the registers.
It looks well with the user-triggered reconfiguration (bit 0 is set), but strange with the error-triggered configuration when 2nd image is missing. The code I am getting is 0x4 and this corresponds (quote from ds)nstatus_source: nSTATUS asserted by an external device as the result of an error
what I was expecting was 0x8 -> CRC error indication. which are the conditions for this bit to be set? does this have any connection with the "Enable error detection CRC" option from the "Device and Pin Options" menu?
