We are planning to use Arraia V as multiprocessors with both ARM and Nios on same FPGA. As to ARM, it will run simulink generated code and use etherenet communication. Now, I'm puzzled as to which IDE I should use: 1. Keil MDK-ARM - seems as a better choice in terms of the generated simulink code tools. or 2. DS-5 - seems that is the offer from Altera http://www.keil.com/arm/rvcomparison.asp Are both options possible using Arria V, i.e. for example can I use the Keil jtag to connect to ARM on Arria V. Thank you for any suggestions and feedback, RanLink Copied
My Friend,
I would say this is just a personal choice. If the cost of both IDE package is about the same or not a huge concern, using an Altera's Arraia V with Altera's IDE choice DS-5 would be a more secured choice as you can get them to be your technical backup support already. Haha... Ranger
