21602 Discussions
About pin processing of unused input pins for Cyclone V.
YTsuj6
FPGA:Cyclone V (5CEBA7F23C7N)
Can I use the input setting IO pin in the open state when it is not used?
There is a model where the FPGA circuit is common and the external circuit is different, so the settings are common.
ShafiqY_Intel
Hi YTsuj6,
The Unused Pins must connect as defined in the Quartus Prime software.
Below are the options for unused pins:
sstrell
You can also set this on an individual pin-by-pin basis using the Pin Planner. Right-click a pin in the Package View, go to Reserved Pins, and select an option.
#work4intel
