21611 Discussions
Adding Hex numbers
Does anyone know how can I add Hex numbers inside the process (VHDL)?
For instance, I want to add x"55" + x"55" but if I'll write " x"55" or x"55" " the answer will be x"55" (the answer should be x"AA").
Idan
--- Quote Start ---
Idan
--- Quote End ---
Of course x"55" or x"55" is x"55" as this is a binary or, used on the vector bitwise.
Addition in VHDL (one of the reasons I prefer Verilog over HDL) requires type conversions as it has quite a strict type checking:
result <= std_logic_vector(unsigned(x"55") + unsigned(x"55"));
Also please note that unless you do know exactly what you do an addition of two vectors with N and M bits require the result to be max(N,M) + 1 bit wide.
Thanks a lot...
I want to add two hex numbers inside the process…
This is my code:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
--USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.NUMERIC_STD.ALL; --I using "conv_std_logic_vector" function
signal TX_checkSum: std_logic_vector (8 downto 0);
begin
process (clk)
begin
if reset='1' then
elsif clk'event and clk='1' then
TX_checkSum <= std_logic_vector(unsigned(x"55") + unsigned(x"55"));
end if;
end process; "
I get the following error:" Error (10408): VHDL error at UART.vhd(139): can't determine type of object at or near string ""01010101"" -- found 25 possible types".
What could be the problem?
