21610 Discussions
Advanced .jbc files with normal compilation flow
Nikolay_Rognlien
Hi.
From the Programmer Utility you can create an advanced .jbc file from a .pof file. (E.g. program configuration and user flash partitions in Max10)
If you enable .jbc file generation through the Device&Pin Options => Programming Files settings, the .jbc file is generated from the .sof file only and only capable of configuring a Max10.
Is there a way to make an advanced .jbc file as part of the normal compilation flow?
Best regards
Nikolay
ShafiqY_Intel
Hi Nikolay,
You can create .jbc file using Quartus Programmer.
Add your .pof file. Choose which CFM/UFM you want to program. (My case I choose CFM0 and UFM)
Then, go to file --> Create JAM, JBC, SVF and ISC file.
Then, choose .jbc file.
I hope this will help.
Cheers.
JChri1
This is not what Nikolay asked about. He already stated that he knows how to do it using the programmer..
The question was
"Is there a way to make an advanced .jbc file as part of the normal compilation flow?"
Nikolay_Rognlien
Hi Shafiq.
There is a project assignment that can potentially be used in this case: POST_FLOW_SCRIPT_FILE
https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/design-software/tcl/auto_processing.html
The next question is therefore:
What is the tcl/shell command to make the advanced .jbc file as you described above?
Nikolay
ShafiqY_Intel
Hi Nikolay,
You can use quartus_cpf command to convert input file (.sof or .pof or .cdf file) to .jbc file.
Here the example the command:
  • quartus_cpf -c <input_sof_file> <output_jbc_file>
  • quartus_cpf -c <input_pof_file> <output_jbc_file>
  • quartus_cpf -c  <input_cdf_file> <output_jbc_file>
Cheers
JChri1
Hi Shafiq
I have tried that and that, both with pof and cdf and it dosn't work. It is as if some option are missing. The messages from the JAM pplayer is also different from when the jbc file is generated be the programmer. The programmer makes more of those DO_*********** (optional)
jbc generated by quartus_cpf
CRC matched: CRC value = 0000FC76h
File format is Jam STAPL ByteCode format
NOTE "CREATOR" = "QUARTUS PRIME JAM COMPOSER 18.1"
NOTE "DATE" = "2020/03/05"
NOTE "DEVICE" = "10M02SC"
NOTE "NEED_FREQUENCY_CONTROL" = "0"
NOTE "FILE" = "ctx_mbf7332D201_ic1.pof"
NOTE "TARGET" = "1"
NOTE "IDCODE" = "031810DD"
NOTE "USERCODE" = "000BAF3E"
NOTE "CHECKSUM" = "006DC5C8"
NOTE "SAVE_DATA" = "DEVICE_DATA"
NOTE "SAVE_DATA_VARIABLES" = "V0, A12, A13, A25, A42, A93, A43, A92, A94, A95, A105, A109, A111"
NOTE "STAPL_VERSION" = "JESD71"
NOTE "JAM_VERSION" = "2.0"
NOTE "ALG_VERSION" = "68"
Actions available in this file:
PROGRAM
  DO_BLANK_CHECK (optional)
  DO_VERIFY (recommended)
  DO_BYPASS_CFM (optional)
  DO_BYPASS_UFM (optional)
  DO_BYPASS_ICB (optional)
  DO_BYPASS_CFM1 (optional)
  DO_READ_USERCODE (optional)
BLANKCHECK
VERIFY
CONFIGURE
  DO_HALT_ON_CHIP_CC (optional)
  DO_IGNORE_IDCODE_ERRORS (optional)
  DO_IGNORE_INTOSC_BYPASS (recommended)
  DO_BYPASS_SECOND_IDCODE_READ (optional)
ERASE
READ_USERCODE
CHECK_IDCODE
Device #1 IDCODE is 031810DD
configuring SRAM device(s)...
Device programming failure
Device configuration failure
jbc generated by programmer
CRC matched: CRC value = 00003C83h
NOTE "CREATOR" = "QUARTUS PRIME JAM COMPOSER 16.1"
NOTE "DATE" = "2020/02/25"
NOTE "FILE" = "ctx_mbf7332D201_ic1_version_2.pof"
NOTE "TARGET" = "1"
NOTE "USERCODE" = "000FA60E"
NOTE "CHECKSUM" = "00702D4F"
NOTE "SAVE_DATA_VARIABLES" = "V0, A12, A13, A25, A43, A92, A94, A95, A105, A109, A111"
NOTE "ALG_VERSION" = "67"
PROGRAM
  DO_DISABLE_ISP_CLAMP (optional)
  DO_REAL_TIME_ISP (optional)
  DO_FORCE_SRAM_DOWNLOAD (optional)
  DO_INIT_CONFIGURATION (optional)
BLANKCHECK
VERIFY
ERASE
READ_USERCODE
CHECK_IDCODE
full-chip erasing Max 10 FPGA device(s) ...
programming Max 10 FPGA CFM0 block at sector 5 ...
programming Max 10 FPGA UFM block at sector 1 ...
programming Max 10 FPGA UFM block at sector 2 ...
verifying Max 10 FPGA CFM0 block at sector 5 ...
verifying Max 10 FPGA UFM block at sector 1 ...
verifying Max 10 FPGA UFM block at sector 2 ...
programming Max 10 FPGA DSM block ...
DONE
ShafiqY_Intel
Hi JChri1,
I send you a forum private message.
Please follow up there.
Luis_Guedes
Hi ShafiqY,
I'm dealing with this same matter when trying to generate a correct JAM file used for MAX10 internal FLASH update.
I managed to generate a working JAM file (using Qartus Programmer) after finding this knowledge base:
https://www.intel.com/content/www/us/en//support/support-resources/knowledge-base/component/2017/how-to-generate-a-jam-file-which-supports-the-option-of-dorealti1.html
That does not quite fit on my development flow as it does not rely on any GUI at all.
I need to find a way to ensure the property "DO_REAL_TIME_ISP" in the JAM files generated directly on "quartus_cpf" as it was possible with older Quartus versions.
Inspecting the Quartus configuration files trying to find how to let this property allways on I've found the "quartus2.qreg" file but unfortunately it does not affect the "quartus_cpf" behavior.
There is another configuration file or procedure available by command line to generate the JAM file with that particular property on?
Luis_Guedes
I've found the solution on MAX10 device's "Configuration User Guide".
On section "3.2.2. Generating Third-Party Programming Files using Intel QuartusPrime Programmer" is described the additional options available on quartus_cpf to generate the JAM file with the desired property "DO_REAL_TIME_ISP".
From the user guide:
"quartus_cpf -c <input_pof_file> <output_jam/jbc_file> -o background_programming=on"
