21147 Discussions
Agilex 5 FPGA Core Supply (Speed Grade)
Nicole04
Good day,
I will initially use a -4 speed grade Agilex 5, E-Series, Group B device and then later on transition to a -6 speed grade option. The power supply I want to use can generate a maximum of 775mV, which is a 3.125% deviation from the required 800mV for the core supply of the -4 device. What will happen if this is the supply voltage?
Kind regards,
Nicole
Fakhrul
Hi Nicole,
You can refer to the datasheet for detailed information. As long as the parameters are within the Recommended Operating Conditions, it shouldn’t be an issue.  Refer : Agilex™ 5 FPGAs and SoCs Device Data Sheet page 20
Let me know if you need further clarification.
Fakhrul
