Good day,
I would like to use the Active Serial (AS) configuration scheme for configuring the Agilex 5 FPGA. I see the Device Configuration User Guide: Agilex™ 5 FPGAs and SoCs gives a list of compatible flash memory in Table 32. I would like to use a QSPI flash device from ISSI, IS25WP512M-RHLE, this device has a dedicated reset pin. Will I be able to use this device?
Kind regards,
Nicole
Hi Nicole04,
Any Quad SPI flash devices that meet both the following criteria, should be supported.
- Supports Serial Flash Discoverable Parameter (SFDP) standard
- Supports dedicated pin reset
Fakhrul
Hi Nicole04,
Fakhrul
