21615 Discussions
Agilex 5 Premium development Kit Compile error
SDavi9
I have a Agilex 5 Premium development Kit and I tried to compile a number of design examples(bts_config & bts_xcvr) on Qurtus Prime Version 25.1.0 and the got the following Error Messages
Error: ERROR: run_flow_command with specified flow 'compile' failed: "Failed".
while executing
"flng::run_flow_command -flow "compile""
while executing
Please could you help me with this
ShengN_Intel
Any further update or concern?
Sheng
ShengN_Intel
May I know how use run the compilation through command or gui?
Sheng
SDavi9
SDavi9
I compiled a very simple design based on Golden_Top design as shown below and it gave the same error !!!!
pushBUTTON1_pressed <= '1' when remote_fpga_user_pb(1) else '0' ;
ShengN_Intel
I try with linux version without any problem. Have you try to clean project?
Sheng
SDavi9
I tried the design example in widows "AS IS" and this is where I got the errors...
ShengN_Intel
Have you try Project -> Clean Project?
SDavi9
Not yet - I will try and let you know....
ShengN_Intel
Sheng
