I am using HPS-first configuration scheme and I can fit FPGA from u-boot(first time it is successfull). Now I want to refit FPGA from running linux system. I am trying to follow this manual
https://device.report/m/dfbc733be8e55f3eeb1bd826b10d227bc67cef0500f56fd4ceedb63459e4e408.pdf
section 6.2. Configuring the FPGA Fabric from Linux, but I am getting error:
# echo fpga_core.dtb > /sys/kernel/config/device-tree/overlays/0/path
sh: write error: Invalid argument
this is my overlay dts file
/dts-v1/;
/plugin/;
fragment@0 {
target-path = "/soc/base_fpga_region";
#address-cells = <1>;
#size-cells = <1>;
__overlay__ {
#size-cells = <1>;
/* ranges = <0x00000000 0xF9000000 0x00200000>;*/
firmware-name = "fpga_core.rbf";
config-complete-timeout-us = <10000000>;
/* sysid@0 {
compatible = "altr,sysid-20.1", "altr,sysid-1.0";
reg = <0x00000000 0x00000008>;
id = <0x12345678>;
timestamp = <0>;
I have tried dts also with commented lines, also without success.
dmesg relevant lines:
STARTUP:
[ 0.036001] FPGA manager framework
[ 1.591366] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.598563] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.606865] Stratix10 SoC FPGA manager soc@0:firmware:svc:fpga-mgr: couldn't get service channel (fpga)
[ 1.706286] stratix10-svc soc@0:firmware:svc: Adding to iommu group 3
[ 1.717674] Intel Service Layer Driver Initialized
[ 1.768068] fpga_manager fpga0: Stratix10 SOC FPGA Manager registered
[ 1.795620] of-fpga-region soc@0:base_fpga_region: FPGA Region probed
Dduring DT overlay apply:
[ 575.816996] OF: overlay: find target, node: /fragment@0, path '/soc/base_fpga_region' not found
[ 575.825722] OF: overlay: init_overlay_changeset() failed, ret = -22
[ 575.831968] create_overlay: Failed to create overlay (err=-22)
in ...intel/socfpga_agilex5.dtsi there is section:
soc: soc@0 {
compatible = "simple-bus";
ranges = <0 0 0 0xffffffff>;
#size-cells = <1>;
device_type = "soc";
interrupt-parent = <&intc>;
base_fpga_region {
#address-cells = <0x2>;
#size-cells = <0x2>;
compatible = "fpga-region";
fpga-mgr = <&fpga_mgr>;
according this page
https://www.rocketboards.org/foswiki/Documentation/IntelFPGAHPSEmbeddedSoftwareRelease
there was problem
FPGA configuration with overlays fails after seeing the following message during Linux boot up: "Stratix10 SoC FPGA manager soc:firmware:svc:fpga-mgr: couldn't get service channel (fpga)"
, but it should be fixed in 24.2 PRO version (I am using 24.3.1 PRO version)
Could you help me wth this problem, please? Is problem the target_path variable?
Hi all,
finally I solved issues with help from Arrow (thank you Tomasz). The necessary things were:
1) to modify u-boot script to exclude any accesses to fabric peripherals (eg USB reset PIO)
echo "Trying to boot Linux from device ${target}";
if test ${target} = "mmc0"; then
mw.l 10d13224 14;
mw.l 10d13228 14;
mw.l 10d1323c 14;
mw.l 10d13234 14;
mw.l 10d13248 14;
mw.l 10d1324C 14;
mw.l 0x10D11028 0x01027fb0 1;
mw.l 0x10c03304 0x410 1;
mw.l 0x10c03300 0x00000410;
mw.l 0x10c03300 0x00000000;
else
echo "mmc0 not found!"
fi
fatload mmc 0:1 ${loadaddr} ${bootfile};
setenv bootargs "bootargs console=ttyS0,115200 root=${mmcroot} rw rootwait";
bootm ${loadaddr};
if test ${target} = "qspi"; then
qspi_clock=0x17d78400;
if ubi part root; then
ubi detach;
mtdparts;
ubi part root;
ubi readvol ${loadaddr} kernel;
ubi detach;
setenv bootargs "earlycon panic=-1 ubi.mtd=1 root=ubi0:rootfs rootfstype=ubifs rw rootwait";
bootm ${loadaddr};
fi
ubi detach;
sf probe;
sf read ${loadaddr} ${qspibootimageaddr} ${bootimagesize};
setenv bootargs "earlycon root=/dev/mtdblock1 rw rootfstype=jffs2 rootwait";
bootm ${loadaddr};
fi
if test ${target} = "nand"; then
ubi part root;
setenv bootargs "earlycon panic=-1 root=${nandroot} rw rootwait rootfstype=ubifs ubi.mtd=1";
bootm ${loadaddr};
fi
2.) To modify and rebuild the devicetree (socfpga_agilex5_axe5_eagle.dts). Remove any references to fabric peripherals - so LEDs sections, whole soc@0 section and &usb31 section.
overlay.dts was also simplified
// SPDX-License-Identifier: GPL-2.0
* Copyright (C) 2024, Arrow Electronics, Incorporated.
/dts-v1/;
/plugin/;
fragment@0 {
target-path = "/soc@0/base_fpga_region";
__overlay__ {
firmware-name = "axe5_eagle_top.hps.core.rbf";
config-complete-timeout-us = <30000000>;
and now fpga_core.rbf can be (for first time) succesfully load also from linux system.
It seems, that target_path variable should be
but after "echo fpga_core.dtb > /sys/kernel/config/device-tree/overlays/0/path" system hangs. This is output on serial line:
[ 39.285147] fpga_manager fpga0: writing fpga_core.rbf to Stratix10 SOC FPGA Manager
PANIC at PC : 0x000000008000b420
Maybe it is necessary to manually disable bridges or something else that is beyond my knowledge...
Any advice is welcome.
Hi all,
mw.l 10d13224 14;
mw.l 10d13228 14;
mw.l 10d1323c 14;
mw.l 10d13234 14;
mw.l 10d13248 14;
mw.l 10d1324C 14;
else
fi
bootm ${loadaddr};
ubi detach;
mtdparts;
ubi part root;
ubi detach;
bootm ${loadaddr};
fi
ubi detach;
sf probe;
bootm ${loadaddr};
fi
ubi part root;
bootm ${loadaddr};
fi
/dts-v1/;
/plugin/;
fragment@0 {
__overlay__ {
