21263 Discussions
Agilex 7 i series serdes capability
number_7
For Agilex 7 i series development kit (4x Ftile)  transceiver data rate support is mentioned as 116Gbps at max.
can i get any reference eye diagrams from intel, in order to verify the capability support for data rate.
thanks
AR_A_Intel
Hello
Welcome to INTEL. We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
To further check, may we know whether your get the reference diagrams yet / your issue has been resolved, or if you're still encountering any problems?
number_7
Hi AR_A_Intel,
    Thanks for considering my query and response.
     I am working on transceiver IP design to check the Serdes capability.  Link for board files referring this link for target device
     part number agib027r31b1e1vaa, to get the board files under Table 3. Documentation in installer package but could not find a link for this particular device -DK-SI-AGI027FB, i have doubt like whether i am referring the correct link can you help on this to get the board files so that i can get the better understanding on available configurations.
     Regarding reference eye diagrams still i didnt get that, so, if possible, can you provide any source to get the eye diagram to have an idea on Data rate range for FGT PMA's which is mentioned as
        1-32 Gbps NRZ
        20-58.125 PAM4
AR_A_Intel
Hi
Thank you for the update. Could you help verify whether FGT or FHT transceivers should be used? Please note that only FHT transceivers can achieve speeds of up to 116 Gbps, while FGT transceivers are limited to a lower data rate. It is important to choose the appropriate transceiver type based on the performance requirements of your design.
https://www.intel.com/content/www/us/en/docs/programmable/683301/current/f-tile-transceiver-performance.html
number_7
      FGT transceiver, requirement is upto 20Gbps
AR_A_Intel
Hi
We apologize for the difficulty happens and delay as I’m out of office recently. Please give me some time to further check with our teammate regarding your issue. I’ll be back with an update.
AR_A_Intel
Hi
For the Agilex 7 I-Series FPGA device with part number AGIB027R31B1E1VAA, reference board files for the DK-SI-AGI027FB development kit should be available through the Intel Agilex development kit documentation. You can access these resources under Intel's Agilex Development Kits. This link provides information on the Agilex AGF027 and AGF023 kits, and Table 3 within the documentation often includes links to board files and configuration guides.
The link is a helpful starting point for understanding the device's capabilities.
·      https://www.intel.com/content/www/us/en/products/details/fpga/agilex/7/item.html
·      https://www.intel.com/content/www/us/en/content-details/779615/agilex-7-fpga-i-series-116-gbps-pam4-lr-transceiver-overview.html
For reference eye diagrams at specific data rates, the Intel Agilex Transceiver PHY User Guide typically details performance metrics like the supported data rate ranges of 1-32 Gbps NRZ and 20-58.125 Gbps PAM4 for FGT PMAs. If these diagrams aren’t included in the public documentation, you may request it through your distributor. Refer link https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
AR_A_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
