I'm trying to program a Cyclone II I bought here (https://rads.stackoverflow.com/amzn/click/B00LEMKR92) using Quartus II 13.0sp1 on Arch Linux. I'm trying to program it with a very simple Verilog program with three inputs and two outputs and a few simple logic functions. I selected the proper model (EP2C5T144C8), assigned the pins to the inputs/outputs, compiled, and ran the programmer. I am using a JTAG USB blaster. When I run jtagconfig, I receive the following output
1) USB-Blaster [2-1.6]
020B10DD EP2C5
However, when I try to program the .sof file created by the compiler, I receive the following error.
Error (209015): Can't configure device. Expected JTAG ID code 0x020B10DD for device 1, but found JTAG ID code 0x000310D9.
If I run the programmer multiple times, I often get different values for the ID code that it found. Does anyone know what's wrong here?
"I am using a JTAG USB blaster. When I run jtagconfig, I receive the following output"
Since 'jtagconfig' command working correctly then this issue may occur due to following reasons,
- Check .sdc file name is same as project name or not, if available.
- Check the below link for cyclone II device,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an039.pdf
https://datasheet.octopart.com/EP2C5T144C8-Altera-datasheet-7627975.pdf
I have not replicated this issue but I hope this might help to you.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
