Hi there, we are using 10AX057H3F34E2SG transceivers for PCIE GEN3.0 x4 lanes for Chip-to-COMe Module(PC module on board) .
As we know, PCIE 3.0 is max. 8GT/s, which is less than 10Gbps data rate max.
A10 Datasheet Table4 indicate that VCCT_GXB and VCCR_GXB should be 0.95 when data rate is less than 12.5Gbps.
However, notes(19) on the bottom of page 10 writes, "To support PCIe* Gen3, this pin must be 1.03 V (± 30 mV) or higher."
So, what the supply voltage should be for our application? 0.95V or 1.03V?
By the way, "1.03V or higher", what's on earth does the "higher" mean ? Can it exceed 1.06V??
Thanks!!!
Hello ,
Answer to your first question : Yes , data rate in datasheet is for each late , here is the Intel Arria 10 transceiver phy guide: Section "Transceiver PHY Architecture Overview"
here is the link for your reference
Answer to your second questions , Yes , you can very well use as long as power consumption is not concern for your application. Keeping at 1.03 V also help to upgrade the data rate in future as per datasheet.
Thank you ,
up
As you mentioned PCIE 3.0 is max datarate is 8 GT/s . Per datasheet if your application is chip to chip , then both Transmitter / Receiver voltage is 0.95V Typical, but if the your application using backplane or datarate > 11.3 Gbps then the voltage is 1.03V.
A10 datasheet Table 4 clearly indicate that VCC_GXB & VCCR_GXB should be 0.95V when datarate is < 11.3 Gbps.
Thank you
Hi sree
I guess the "Data rate" in this Intel datasheet means for EACH trasceiver lane?? Also, I think it is also ok for chi-to-chip to use 1.03V even if the data rate is lower than 11.3Gbps as long as power consumption is acceptable.
In our application, we have PCIe3.0 x4 for Board-to-Board connection ( chip to PC-module, 8Gbps per lane, total 32Gbps). And we also have chip-to-chip connection of x10 transceiver lanes on one Board, with 8Gbps per lane, total 80Gbps for now, and possibly upgrade to higer data rate in future.
I think we CAN use 0.95V for NOW. But since power consumption is not a concern, we better use 1.03V. How do you think? Thanks a lot!
Hello ,
Thank you ,
Thanks, Sree. You answer really helps.
